proper p trap orientation/flow direction?
McEnzo
Montreal
I've searched here and on the internet but have found contradicting information compared to available p-traps for sale. So which side really connects to the drain and which to the j-pipe/waste pipe?
McEnzo
Montreal
McEnzo
Montreal
Looking at the p trap that is not glue-together, the sweep is on the drain side, but look at the image i uploaded, the height to the j-bend does not apply in my case since one side of the p trap is not higher than the other. I just to know if the p trap flows better one way or the other?
McEnzo
Montreal
Or in this picture we can clearly see that the sweeping part is on the j bend side and there's no way this could be backwards since one side is definitely higher than the other.
Now you are throwing something else in. Will a deeper water seal flow worse or better than a shallower water seal? Neglecting the water seal depth thing, the top one would flow faster. But it will be a small and probably unnoticeable difference.
I may be missing your point on this one. Were you saying that the asymmetry on the disposal picture trap was as intended? Yep. That is the deal with the brachistochrone curve curve thing. https://en.wikipedia.org/wiki/Brachistochrone_curve Still, a symmetrical trap or even backwards curve will drain fine. Using one backwards from the design curve will not violate code and it will still drain water well in practice.
McEnzo
Montreal
You got my point exactly, the water seal height will be not applicable, it's all a question of which side goes on the drain side, steep angle or sweeping? Clearer picture attached.
Steep ideally, presuming you mean the input side as the drain side.
