Proper fitting question
Krow
Ontario, Canada
Considering there's no wall available between the drain and the stack going down to the basement, how is it possible to vent in this scenario? Consider a drain that goes down to the basement 3 feet away, but is in the middle of a room, how can you vent this?
What you have to do is raise the vent as high as you can above the horizontal plane of the drain and go to the nearest wall possible and come up at your 6" above your fixture. Code in Ontario prefers that you raise the vent immediatly, where ever possible
exeunt
Stouffville, Ontario, Canada
Thanks for taking the time to draw the diagram. That's effectively what I plan on doing, which unforutnately means a few feet of horizontal (but sloped) venting before it gets to the vertical at the nearest wall and up towards venting. The inspector issuing my permit basically told me they don't review plumbing diagrams, they'll tell me if its wrong during the plumbing rough-in inspection. Great :)
mjsmith0
Los Angeles, CA
I'm just a DIY'r but ran into a similar problem. Would this solution work for you? It's a longer route to the main drain and you need enough vertical room for the added slope, but at least there is no flat venting.
NHmaster3015
The granite state
Mass will let you flat vent but we are IPC and it cant be done. A lot of guys try rolling the wye and then going horizontal but even that won't fly with most inspectors.
exeunt
That might in fact be the way I need to go.. That's a good idea.. Vertical may not be a problem for me since it seems that when they built my house, they built the ceiling in the washroom below an extra 6" lower, giving me more room :) Considering the inspector won't even tell me its wrong until I've already done it, maybe this is the best way to go. Seems silly that I need to make the piping go in circles to be within code, almost looks like i could install one of those swirlly straws in the loop for effect :)
Krow
Ontario, Canada
Are you planning on making the waste water dizzy before it goes to the main stack?? Why would you want to add extra changes in direction for your waste water? Better chances for blockages to happen
You could do what you want, its your house, but my suggestion will pass any Ontario juresdiction.The best direction from point A to point B is usually in a straight line
exeunt
Looks like I have some thinking to do. Not being a plumber myself I don't know what would pass code. Some people have said that if it goes horizontal below the flood line that would be against code. Since I'm not actually attaching it to the 3" line on the 2nd floor any more, I may do as mjsmith suggested, by taking it over to the wall, then making a 45 degree turn towards the curb and then down to the basement. That would prevent extra turns, as well as prevent a horizontal vent line below the flood line.
Thanks for everyone's input!
Krow
Ontario, Canada
Just make sure that the pipe you run does not exceed 20Ft from the p-trap to the main stack, otherwise you will have to install cleanouts at 20ft intervals
