OldOak
My house has a well and the water lines are copper with the exception of some of the upstairs bathroom. There is currently a bonding wire that is clamped on shortly after the water softener and runs to the electrical panel.
I'm going to be replacing the water softener- which currently uses brass valves, with new plastic fittings. I know I need a bonding kit to jump from copper pipe to copper pipe since the new softener and fittings will break the electrical bond.
My question is this- if I were to replace several feet of pipe around the water softener with PEX or CPVC to install some new sediment filters, is it acceptable to jump from the existing house copper pipe to the main water line coming in from the well to maintain continuity? It might be 5-10 or so feet of copper pipe I'd be replacing and would need to bond across. The original bonding wire running to the electric panel would not be disturbed by this install, it would be on the "house" side of the copper pipe.
I see kits that come with 2' of copper wire, but did not know if I could use similar gauge clamps and wire to cover a large break of say 5-10 feet of plastic pipe to maintain continuity.
Thanks for any info you can provide.
