System info (not programmed) | | | | |
salt lb/cuft | : | 6 | ; | A choice ( efficiency vs capacity) |
BLFC | : | 0.25 | ; | Brine Refill rate GPM |
cubic ft resin | : | 2.0 | ; | Same as (nominal grains/32,000) |
Raw hardness | : | 16.0 | ; | including iron etc |
Estimated gal/day | : | 240.0 | ; | 60 gal per person typical calc |
Estimated days each regen | : | 8.7 | ; | presuming days each use reserve capacity |
Fleck 7000SXT Settings: | | | | |
DF | = | Gal | ; | Units |
VT | = | dF2b | ; | Downflw/Upflw, Double Backwash |
CT | = | Fd | ; | Meter Delayed regen trigger |
C | = | 40.0 | ; | capacity in 1000 grains |
H | = | 19 | ; | Hardness grains after compensation |
RS | = | cr | ; | Cr = base reserve on recent experience |
CR | = | 0 | ; | 0 is default (leave it) |
DO | = | 14 | ; | Day Override (typ 28 if no iron/Mn) |
RT | = | 2:00 | ; | Regen time (default 2 AM) |
B1 | = | 8 | ; | Backwash 1 (minutes) |
Bd | = | 60 | ; | Brine draw minutes |
B2 | = | 5 | ; | Backwash 2 (minutes) |
RR | = | 6 | ; | Rapid Rinse minutes |
BF | = | 16 | ; | Brine fill minutes |
FM | = | t1.2 (usual) | ; | t1.2 is default flow meter |
Your BD was low, and might have resulted in some residual salt in the first water after regen.
Don't blame the installer for the lean settings. CA wants it that way. I am not a pro, so I am suggesting more luxurious (less Spartan) settings.
Your Backwash minutes were fine.
Note the numbers below are not quite a match for a 16 minute
Revised based on numbers from
https://terrylove.com/forums/index.php?threads/help-for-programming-fleck-5810.82673/#post-595983
The less salt per cubic ft, the more salt efficient, but more hardness breakthrough.
Revised based on number from
BLFC = 0.25
cubic ft resin = 2
Alternative C and BF pairs:
lb/cuft ; C= ; BF= ; grains/pound of salt
2.250 ; 22.2 ; 6 ; 6564
2.625 ; 25.0 ; 7 ; 6362
3.000 ; 27.7 ; 8 ; 6147
3.375 ; 30.0 ; 9 ; 5932
3.750 ; 32.2 ; 10 ; 5723
4.125 ; 34.2 ; 11 ; 5522
4.500 ; 36.0 ; 12 ; 5332 # 12 minutes BF-- what you have been running.
4.875 ; 37.7 ; 13 ; 5152
5.250 ; 39.2 ; 14 ; 4982
5.625 ; 40.7 ; 15 ; 4821
6.000 ; 42.0 ; 16 ; 4670 #what I selected above-- about as lean as most go
6.375 ; 43.3 ; 17 ; 4528
6.750 ; 44.5 ; 18 ; 4393
7.125 ; 45.6 ; 19 ; 4267
7.500 ; 46.6 ; 20 ; 4147
7.875 ; 47.6 ; 21 ; 4033 #popular setting
8.250 ; 48.6 ; 22 ; 3925 #popular setting softer
8.625 ; 49.5 ; 23 ; 3823
9.000 ; 50.3 ; 24 ; 3726
9.375 ; 51.1 ; 25 ; 3634
9.750 ; 51.9 ; 26 ; 3546
10.125 ; 52.6 ; 27 ; 3463
10.500 ; 53.3 ; 28 ; 3383
10.875 ; 53.9 ; 29 ; 3306
11.250 ; 54.6 ; 30 ; 3234
11.625 ; 55.2 ; 31 ; 3164
12.000 ; 55.7 ; 32 ; 3097
12.375 ; 56.3 ; 33 ; 3033
12.750 ; 56.8 ; 34 ; 2971
13.125 ; 57.3 ; 35 ; 2912
13.500 ; 57.8 ; 36 ; 2856
13.875 ; 58.3 ; 37 ; 2801
14.250 ; 58.8 ; 38 ; 2749
14.625 ; 59.2 ; 39 ; 2698
15.000 ; 59.6 ; 40 ; 2649
15.375 ; 60.0 ; 41 ; 2602
15.750 ; 60.4 ; 42 ; 2557
16.125 ; 60.8 ; 43 ; 2513
