Programming fleck sxt7000
Sbunn
Orange, ca
I have had this water softener for a couple years but I think it could be programmed more efficiently. I have a 5 person family but one is a baby and doesn't use much water so I am guessing that calculating for 4 would be more accurate - 2 adults and 2 kids age 8 and 10. So I am guessing maybe 60 gallons of water a day each for 240. Hardness in orange ca is 16. The softener is 64000 grain/2 cu ft.and the blfc is .25, injector is 0.
Current settings:
DF: GAL
VT: St2b (Standard Downflow/Upflow Double Backwash)
CT: Fd (Meter Flow Delayed)
C: 30k (capacity)
H: 16 (hardness)
RS: cr
DO: 8 (Day override)
RT: 2:00AM
B1: 6 mins (back wash)
BD: 45 mins (brine draw)
B2: 5 (backwash)
RR: 6 mins (rapid rinse)
BF: 12 mins
FM: t1.2 - 1.5'' Turbine Meter (7000 default)
Any advice on how I did with the settings? Thanks.
System info (not programmed)
salt lb/cuft​
6​
A choice ( efficiency vs capacity)​
BLFC​
0.25​
Brine Refill rate GPM​
cubic ft resin​
2.0​
Same as (nominal grains/32,000)​
Raw hardness​
16.0​
including iron etc​
Estimated gal/day​
240.0​
60 gal per person typical calc​
Estimated days each regen​
8.7​
presuming days each use reserve capacity​
Fleck 7000SXT Settings:
DF​
Gal​
Units​
VT​
dF2b​
Downflw/Upflw, Double Backwash​
CT​
Fd​
Meter Delayed regen trigger​
C​
40.0​
capacity in 1000 grains​
H​
19​
Hardness grains after compensation​
RS​
cr​
Cr = base reserve on recent experience​
CR​
0​
0 is default (leave it)​
DO​
14​
Day Override (typ 28 if no iron/Mn)​
RT​
2:00​
Regen time (default 2 AM)​
B1​
8​
Backwash 1 (minutes)​
Bd​
60​
Brine draw minutes​
B2​
5​
Backwash 2 (minutes)​
RR​
6​
Rapid Rinse minutes​
BF​
16​
Brine fill minutes​
FM​
t1.2 (usual)​
t1.2 is default flow meter​
Your BD was low, and might have resulted in some residual salt in the first water after regen.
Don't blame the installer for the lean settings. CA wants it that way. I am not a pro, so I am suggesting more luxurious (less Spartan) settings.
Your Backwash minutes were fine.
Note the numbers below are not quite a match for a 16 minute
Revised based on numbers from https://terrylove.com/forums/index.php?threads/help-for-programming-fleck-5810.82673/#post-595983
The less salt per cubic ft, the more salt efficient, but more hardness breakthrough.
Revised based on number from https://terrylove.com/forums/index.php?threads/help-for-programming-fleck-5810.82673/#post-595983
BLFC = 0.25
cubic ft resin = 2
Alternative C and BF pairs:
lb/cuft ; C= ; BF= ; grains/pound of salt
2.250 ; 22.2 ; 6 ; 6564
2.625 ; 25.0 ; 7 ; 6362
3.000 ; 27.7 ; 8 ; 6147
3.375 ; 30.0 ; 9 ; 5932
3.750 ; 32.2 ; 10 ; 5723
4.125 ; 34.2 ; 11 ; 5522
4.500 ; 36.0 ; 12 ; 5332 # 12 minutes BF-- what you have been running.
4.875 ; 37.7 ; 13 ; 5152
5.250 ; 39.2 ; 14 ; 4982
5.625 ; 40.7 ; 15 ; 4821
6.000 ; 42.0 ; 16 ; 4670 #what I selected above-- about as lean as most go
6.375 ; 43.3 ; 17 ; 4528
6.750 ; 44.5 ; 18 ; 4393
7.125 ; 45.6 ; 19 ; 4267
7.500 ; 46.6 ; 20 ; 4147
7.875 ; 47.6 ; 21 ; 4033 #popular setting
8.250 ; 48.6 ; 22 ; 3925 #popular setting softer
8.625 ; 49.5 ; 23 ; 3823
9.000 ; 50.3 ; 24 ; 3726
9.375 ; 51.1 ; 25 ; 3634
9.750 ; 51.9 ; 26 ; 3546
10.125 ; 52.6 ; 27 ; 3463
10.500 ; 53.3 ; 28 ; 3383
10.875 ; 53.9 ; 29 ; 3306
11.250 ; 54.6 ; 30 ; 3234
11.625 ; 55.2 ; 31 ; 3164
12.000 ; 55.7 ; 32 ; 3097
12.375 ; 56.3 ; 33 ; 3033
12.750 ; 56.8 ; 34 ; 2971
13.125 ; 57.3 ; 35 ; 2912
13.500 ; 57.8 ; 36 ; 2856
13.875 ; 58.3 ; 37 ; 2801
14.250 ; 58.8 ; 38 ; 2749
14.625 ; 59.2 ; 39 ; 2698
15.000 ; 59.6 ; 40 ; 2649
15.375 ; 60.0 ; 41 ; 2602
15.750 ; 60.4 ; 42 ; 2557
16.125 ; 60.8 ; 43 ; 2513
Sbunn
Orange, ca
salt lb/cuft​
6​
BLFC​
0.25​
cubic ft resin​
2.0​
Raw hardness​
16.0​
including iron etc​
Estimated gal/day​
240.0​
8.7​
DF​
Gal​
Units​
VT​
dF2b​
CT​
Fd​
C​
40.0​
H​
19​
RS​
cr​
CR​
0​
DO​
14​
RT​
2:00​
B1​
8​
Bd​
60​
Brine draw minutes​
B2​
5​
RR​
6​
BF​
16​
Brine fill minutes​
FM​
t1.2 (usual)​
BLFC = 0.25
cubic ft resin = 2
Thank you! So when kids get older and use more water, do I just increase c and the corresponding bf?
No adjustments. When you use the automatic settings, the valve will adjust to what it sees, and change the reserve on its own.
The gallons in what I wrote is to make the prediction of how often it will regen. It will take time for the valve to gather data, so it might regen early for a while.
