Problem: Replace galvanized in bathroom over basement or crawlspace without opening the walls. Presuming you can remove or displace the existing galvanized in the plumbing wall, how do you fit the new PEX?
Suggestion for needed product:
Blue represents PEX.
Brown represents wall.
Clearing out the old galvanized? Improvise. Unscrew and remove what you can. Abandon the rest.
- Stubout with bigger radius that can be rotated into the plumbing wall
- PEX ready tip, attach before or after fishing bottom end of PEX
- integral plate that can be attached with screws or anchors to existing finished wall
- compatible escutcheon that covers plate
- room end is ready for valve (compression or, alternatively, threaded)
