I recently installed a shallow well. I am not able to get enough water to maintain my sprinkler but do get a stead flow. So I decided to hook up a sprinkler valve along with a reverse acting pressure switch to keep the pump running but stop the water flow when the pressure drops to low.
I purchased a Square D 9013FRG2J23 which comes set to close at 40 psi and open at 20 psi. This switch is rated for a one horsepower pump. I am using a 24 volt AC sprinkler valve and a orbit timer to power the switch and valve.
The first switch would not operate at the factory set pressures. It would open at 20 psi but I was unable to get it to close above 30 psi. I called the company I purchased the switch from and they sent me a replacement and did not require me to return the old one. I installed the new one and it opens at 20 and closes at 40 but when the pressure decreases to 20 psi the contacts do not fully open. They open slightly and there is arcing between the contacts. This causes the valve to close but causes two problems.
1. The arcing continues which will probably damage the contacts.
2. The time switches to rain delay which is probably a reaction to the arcing.
The problem seems to be that the pressure decrease causes the contacts to start to open but the valve closes before the contacts full spring open. If I drop the pressure by opening a bleed value the contacts do full open.
Adjusting the pressure settings does not seem to help.
Does this sound like a defective switch or is it because of the low current?
The original switch did not have this problem but it would not adjust to the higher operating pressure (with the small spring tightened to the max the pressure would not reach above 30 PSI).
Can you think of a solution if the problem is not a faulty switch?
