Macki
i recently had my 20 yo 1hp sub pump replaced. During installation there was a QD control box with a little fuse pumpsaver installed. These components were made to go together, not some cobbled together piece. When my pump shuts off there sounds to be a relay clicking. I suspect it is a trouble light, however with the control panel plugged in you cannot see the lights, and with it out there is not power to them.
I suspect there is either an issue with some component of the system, or it was not calibrated correctly. I cannot find direction for calibrating.
Can someone give me some direction on how you are supposed to see the flashing led lights, and how you are supposed to calibrate it when unplugging it is the only way I see to get into it?
Thanks,
Thanks,
