jeffmitchell
Hey guys. I recently purchased a home that had two side by side water heaters in the basement and now only has one. The current set up is that the hot water outlet has a T and then connects to both main 3/4 lines that supply the entire house. They basically installed a loop to connect both pipes. 4BR 2.5BA home. Family of 4. It is a single 50 gallon gas tank which seems to suffice as we never run out of hot water. The only problem is it seems as some faucets take a really long time to get warm water to them. Specifically the kitchen sink. I need to waste roughly 6 gallons to get warm water. I would like to reduce/eliminate this waste. There are two 3/4 hot water supply lines that run the entire length of the basement next to each other. I am comfortable with working with plumbing and wondering if I should abandon one of the lines and tap in any of the branch lines to one main line?? I don't want to create any flow issues or any other unforeseen problems.
Can someone tell me what some reasons are for a home to have two water heaters and what problems could be caused by switching to only one? Other than my obvious problem. I haven't looked yet but would guess maybe it was to have one servicing each tub. House was built in late 80s.
