Rman
Master mechanic
Ok I know its only july but I had a new well drilled in march 2018 and the feed line from the well head to the house I'm concerned it may freeze this winter. Why because the frost level here is 42 inches deep
The pitless is 48 inches below grade but because the house is over a crawl space the lowest I could drill into
the crawl space is just above the footings at 32 inches. Yes the pipe is now covered after the inspection was done I was not home to stop the workers. Now I wish I would have wrapped the pipe with electric heat tape
Could I use a type of heat blanket for the 5 horizontal feet from the house (well is 10 feet from house) or even bury maybe a foot below grade heat tape in a zig-zag fassion to prevent pipe from freezing??
Our Jan temps go to -15 F. Any suggestions please while the ground is not frozen. Also due to side lot restrictions I cannot get a machine to dig down to the pipe. This was hand dug by two strongback guys
Thanks
Thanks
