Wild at heart
The pressure vessel switch stopped working and the pressure vessel tank was full of water ( but no water coming out the taps in house ) so I did the following:
Turned off Elec supply,
Turned on taps in house and used a compressor to blow the water out of the tank
Air pressure was low so increased it to 58 psi as the cut in/off is set at 60/80
Changed pressure switch
Turned off taps in house
Switched Elec supply back on and put the pump back on.
Pressure went upto 80 and cut off, turned taps back on/off to check it cut in again at 60 which it does.
Water pressure in house is correct.
Problem is that the pressure vessel is empty of water ( never filled when I turned the pump back on ) but pump is cutting in/ out as it should be at 60/80 and the water pressure in the house is correct.
Only thing I forgot to do when turning the system back on was to shut the valve for the presure tank so basically I didn't build the pressure up in the tank before letting the water back into the house!
Is that what i have done wrong? or is the problem something else??
Any help would be greatly appreciated.
