Ntcarson
Hi All! With lots of help from you all, I've prepped for my pressure test on the DWV rebuild of this 1938 house. With the exception of 2" and 4" threaded clean-out plugs, my only leak is a slow drip at the joint circled in the picture, at the base of my attic vent stack.
Since this is the attic and, barring much larger issues, will never be under pressure, or leak. Is there a product or technique that can "simply" strengthen this joint and get it past the 15 minute pressure test? I've read about using the vacuum approach and sucking glue through, but that seems a bit complicated for this quandry.
Your consideration and advice is greatly appreciated! Thank you! Neil
