I've recently purchased a 20-year old home on a well in the mountains. I've never had a well before and am learning on the fly.
I replaced the well pump about 6 months ago. At that time I also learned a little about these pressure tanks, and saw some discoloured water from the first tank which made me think the bladder had degraded (yet I see nothing throughout the house and it's been fine since). After some research, I'm not convinced the system is really set up correctly. But I'm not sure it's worth tampering with since pressure and plumbing in the house are working fine. I only ask, because I'm about to make some other modifications and now would be the time to change this setup as well.
I have a 10GPM well pump (250' deep) feeds directly into these two tanks, both rated 220 gallons (which i assume means they are each more like 110 gallons?). The pressure switch is at the front end, not in between the tanks, as well as the gauge. The tanks are connected by 1 1/2" pipe and are about 3 feet apart. The pressure switch says it's 30/50 and both tanks read 46 psi at present.
a) should I move the switch to be between the tanks rather than at the head?
b) could I use the NTP valves on the second tank tee for the switch and gauge (freeing up the first NTP for my soda ash system I'm tapping in before the tanks)?
c) I don't see any pressure relief valves at the head of either tank - disaster potential?
d) if the first tank (grey) is bad, why am I not seeing nasty water feed throughout the house plumbing?
More curious than anything since I'm new to the setup. As I said, it seems to be working fine and I don't intend to screw with it just for fun. I'm more concerned about future problems if these tandem tanks aren't correctly setup.
