Hey Guys, Gals-
The last month or so I have noticed my water pressure tank is taking 15-20 minutes to fill. I have a Mclean Iron filtration system and 20 year old pump 300 feet down in a drilled well. The business that installed the whole system and well believe that I need a new pump and to set it down further
I know that the pump is old..but my house is on the market, and I have been dumping cash into necessary repairs as well as cosmetics. A few more details from the plumber that came out-
He replaced the pressure switch
We took the cap off from the well and the pump is pushing 100 PSI.
The well was low due to a leaky toilet, but he said my well recovery is good so if that was the culprit, it would clear up- it did not.
Bypassed the filter and same issue.
Ruled out leaks in the house, and from the pump to the house.
He said the pump is measuring 6.8 amps, when it should be up to 7.5+
He said the hydrocharger before my tank isnt sucking as much air as it should- Now if my pump is pushing 100 PSI, i have good well recovery i am wondering why they are opting to replace the pump.. I am wondering if the hydrocharger could be plugged?
