Pressure Tank Readings
HiQ
Manitoba
Okay this might be a dumb question, but I’m trying to diagnose a failing pressure tank. Empty, it should be 2psi below pressure switch cut in.
When the pump finishing cycling and nothing is using water, it should be pretty close to pressure switch cut off pressure, no? Maybe a psi or two loss due to lines, etc?
Just checked mine yesterday and it was 0 psi. So I aired it up, but it’s probably toast. It should still fill with water and get up to pressure though right? It will then also supply pressure until it drops to cut in pressure before the pump turns back on? Just a much shorter cycle time vs a properly working pressure tank?
Any reason I’d get horrible pressure at the tap and the pump wouldn’t turn back on? Clogged filter after the tank before the tap?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
The bladder is probably bad or the air pressure would not be at zero. Even when you air it up sometimes the broken bladder will seal over the inlet/outlet hole and not let water in or out. That should have nothing to do with the pressure switch starting the pump. For that I would check the nipple the pressure switch is screwed into to see if it is clogged. Cycling on and off makes the tank bladder go up and down like bending a wire back and forth until it is broken.
HiQ
Manitoba
Hmm... Okay so until I can get this thing replaced I should just turn the tank off or leave it on?
I’ll take a look at the pressure switch tonight. It’s brand new but maybe it sucked in some crap.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
You ask a bunch of questions about how the pump system should work, but you didn't tell us what problem you are having?
Yes low pressure at the taps could be a clogged filter. But what is the pressure gauge saying while you are seeing low pressure at the tap?
HiQ
Manitoba
Well it’s been interesting to say the least. First I had a gate valve seize closed but look like it was functioning properly. Replaced that. Pump primes and pumps water. It was functioning well last night. Then this morning it worked fine for my wife’s shower and I got a tiny amount of pressure for my shower after hers.
Pump wouldn’t kick in (still thought there was enough pressure) so I assume the clogged filter or as you thought clogged pressure switch. I’ll check both when I get home.
I just swapped the filter yesterday so I’m leaning to the pressure switch. But if I open the filter drain line it seems like it has lots of pressure and then the pump will cycle when it goes down. So I’m somehow not getting pressure past the filter or softener or through the lines. Air lock somewhere? No clue.
Pressure gauge isn’t hooked up at the moment (I know I know). Had some issues with fixing all the plumbing and the new pump didn’t have a port for it and I haven’t bought a tee and reducer yet.
HiQ
Manitoba
Genius! Just grabbed one at the store. Hopefully I can figure this out tonight with some more info otherwise I’ll be back
HiQ
Manitoba
Weird. Easy enough fix I guess. No pressure through the main filter in the house. Disconnected it and run water out the bottom. Maybe cleared some junk that must have been clogging it. Back together and it functions perfectly. For now. Haha. I’ll see if I get a shower in tomorrow morning. Gauge is a lifesaver. Who would’ve thought. Haha. Thanks everyone.
