Seth Clayton
Hi all!
So we leave our house for 3 months in the winter each year. We return periodically for short visits, so we don't usually shut the water or heat off. We're on a well. At some point this winter, one of the faucet cartridges failed on an upstairs tub/shower and water leaked into the tub and down the drain (not sure how long this went on before it was found). I had a friend turn off the valve coming out of the pressure tank to the whole house to stop the leak until I came home to replace the faucet cartridge. I replaced the cartridge with no issues today, but when I opened the valve at the pressure tank, none of the faucets in the house would maintain pressure for more than a few seconds before the water slowed to a very weak stream. I suspected the pressure switch was bad at the pressure tank. I replaced it with a new 40/60 switch, and when I turned it back on it cut the pump off when the tank hit 40psi on a new pressure gauge that I installed along with the switch. I assumed that the "new" switch may have been defective, so I returned it for another. Installed that one, and I'm experiencing the same cutoff at 40psi as the first replacement. Any ideas what could be causing this? Is the well pump toast?
TIA
TIA
