ir0nrat
I am getting ready to replace a leaking pressure switch when I realize the pressure switch is a 40/60 but the tank is 30/50. The pressure gauge normally reads about 50 psi (which I'm guessing can't be good for the tank). What are your thoughts on replacing the tank with one rated 40/60, replacing the switch with a 30/50, or just keeping the switch a 40/60 and set the air pressure accordingly. I do occasionally have spitting at the faucets (but not frequently) so a replacement tank may be a possibility, but mostly everything works ok (except for the leaks).
Thanks in advance.
Thanks in advance.
