JohnBoyJimBob
I was servicing an older residential system which has an ordinary new fibreglass pressure tank and new pressure switch, pumping from a submersible pump inside a drilled well. Switch turns pump on at 30 PSI, off at 50 PSI, as expected. Tank is normally pressurized to 28 PSI.
What I can't explain: after the pressure switch shuts off the pump, the system pressure continues to rise another 15 PSI.
Any explanations for this behavior?
