Assuming a double union the companys make a jumper for use during construction should be available through supplier ( made of pvc should be cheap ) throw that on if your only running 70 psi or so it should be ok for a day or so see how performance is.
a lot of differant ideas , I like using the gage and noting pressure drops myself though Im not so sure what the numbers should be. also you need a place to put the gage I guess on a bib. It be a help to check pressure drop on both sides of regulater too just in case its a problem unrelated to regulator but upstream of it.
My house has an 1 1/2 service and regulator but I reduced it to 1 1/4 reg when replacing a bad regulator. because a 3 bath home with 100 psi I figure why pay more for a bigger reg its been fine last few years
