Joe Clark
Good morning, I am new to the forum, and I have an issue (surprise right!)
I have a fairly shallow well for my area, we are at about 150 feet. The well is about 8years old and we have had issues since about 2 months after it going in, I wont bore you with those details.
The pump seems to be working correctly and the pressure tank seems to be working as well (it is a galvanized type, really not much that can go wrong with it). Here is what is happening. when the water has not been on for a while (20-30mins) and the tank is up to pressure and you run water in the house the pressure is fine, but once you run it long enough to bleed the pressure tank the water flow gets real low. If you are using a hose outside, it will get to the point that it almost trickles out the end of the hose. Now at this point if you turn the water off and wait 20mins the water will come out almost 10ft from the hose, again until the pressure tank is depleted.
I think my well is shot, but I am not sure, any suggestions. I wouldn't think that the pump would only last 8yrs. My parents house has had the same pump for almost 20 and my neighbor swears he has never replaced his and he had the well dug almost 30yrs ago.
If the pump is shot, how difficult is it to replace myself? I really don't have a couple thousand dollars to spend on the well right now.
Thanks in advance -Joe
