Theeokie
Hello all,
I have a 1 acre market garden on land that I've rented. The water supply for my plot comes from a well that 3oish feet lower in elevation and maybe 400'+ feet away. As far as I can tell the main line up to my area in 3/4" poly the whole way (its very convoluted what the actual path is and has been scabbed together over the years.)
This water system also feeds several homes surrounding the field that I am farming. I have measured the resting PSI at about 22, once I start using stuff it will drop down to maybe 8. Best case scenario I would like to be able to use 10 sprinklers at the same time I currently have these with lavender heads https://www.senninger.com/irrigation-product/xcel-wobblertm.
Currently I can run 3 at a time and its a real drag having to constantly shift which once are in use.
Could I put a bladder pressure tank inline to help with this problem what sort of other hardware would I need? I do not have easy access to power so inline pumps are not an ideal solution.
Thanks in advance for your advice.
