houndzilla
My plumbers have wrapped up rough-in for my basement project. Everything turned out pretty great, couple hiccups but all in all
I have a system drain down hose bib right after my water meter, I attached a Watts pressure gauge because I was curious about what kind of PSI the city is giving me. The gauge also has a red indicator hand for highest registered reading.
PSI is ~60, which is perfect. However, on two occasions I've checked the dial and once the red hand was at 180 PSI and another time it was off the dial.
Some tidbits about the new copper installation:
These spikes have only happened twice over a 6 day period. Is there anything I can do to rule out that a valve in my house isn't causing this spike in pressure? There is a hose bib that taps off just after the drain down where the pressure gauges is attached, is there a chance that it could be causing the spikes?
-no mechanical hammer arrestors installed (not code and I didn't request them), only air chambers.
-thermal expansion tank just before cold water enters WH (unsure if precharge on tank was adjusted, factory charge is 40PSI according to spec sheet). I need to check and adjust ASAP.
