I have a 4" 110ft well (PVC casing, 30ft static water level, pump is set at 80ft) with a 1/2 HP submersible pump, 40/60 switch and a well X-trol 302 bladder tank (set to the proper pre-charge pressure, 38psi).
At times I experience a water pressure differential that seems to be about 7-10psi drop throughout the pump cycle. I have not noted exactly the conditions when this occurs though. This happens with my outside spigots as well as household treated water.
Can atmospheric conditions affect the static and dynamic water pressure or flow rates from a submersible well or the static air pressure in the bladder tank?
So can anyone explain this phenomenon?
I don,t want a long drawn out debate over this. So I would ask any experienced well installers for their opinions.
Thank you,
RJ
Thank you,
RJ
