Adam G
I recently installed a pressure balance valve with a single handle in my new shower to replace an old dual handle system. The dual handle system had incredible pressure on both the hot and cold.
When the single handle is at the midpoint the pressure is great. I assume this is because it is mixing the maximum amount of hot can cold water 50/50.
However, I like to take very hot showers. When I move it beyond the midpoint the pressure drops. Not a lot, but enough to notice and wish it was back at max pressure. Maybe 10-20% less. I played with the anti-scald setting and didn't see much improvement.
Would switching to a Thermostatic valve fix this problem, so that even on the hotter settings I would get the max pressure available? Or should the pressure balance valve when on the hotter setting still maintain the same pressure it had at the midpoint?
