Hungry Elf
Good evening. I could not find the answer I was looking for in another thread so here is my problem.
I recently noticed a little bang similar to a loose pipe somewhere in the house. Started my investigation ie. poked holes here and there trying to find the source of my problem. I finally figured that it was coming from behind the shower. I called a plumber and he said that I needed to replace the pressure balance valve because the one installed (aquadis) is junk. I went online to find that some people had a similar issue and by replacing the cartridge, the problem was solved. I tried a new cartridge and that did not change anything except the sound seemed a bit louder. My question to you is can the "casing" of the valve ( the portion where the hot and cold pipes are connected) cause this sound? Thanks
