Sparty007
- Messages
- 38
- Reaction score
- 0
- Points
- 6
All,
Thanks for all the great advice - you've given me (and others I have used) over the years as a DIY homeowner. A few years ago my wife and I had our first child and moved into a brand new construction home and thought my DIY days were over...... so the shower saga begins.
Builder installed these shower valves (2 in the master shower)
All was fine until we were experiencing water hammer, called a local plumber and he came out and got it to go away by plying with the internal stops (not 100% sure what he did) but it stopped. A few weeks later the shower head in question started leaking/dripping slowly but enough to be an issue. Called the plumber back again and he claimed it was the cartridge (on this valve a washerless cartridge). After 5 times back with the wrong cartridge he claims he installed the new cartridge and the leak continues so he said it must be the shower valve is defective and needs to be replaced.
Any advice if that seems reasonable or should I try to pull the cartridge and re-install? Are there any tips/tricks to look for or things I should be before swapping out the shower valves (would go with a more established/reliable brand).
Sorry - if any other info/pictures would be helpful let me know. I'm looking to tackle this over the Holiday when I have some time off work. If its a full on swap of the valves I'll be hiring a plumber as of course there are no access panels and one valve is on an exterior wall.... (sigh).
Thanks in advance for any assistance you can provide.
