augielocost
Hello - I am adding some venting to a very old house that needs more. I'm moving the toilet to take advantage of the new vertical vent and am wondering if there is a preferred location of where the sink connects to the vertical stack - above or below the toilet inlet. I cannot use a combination fitting to have both sink and toilet enter at the same vertical location and need to have separate connection points. The house is governed by IPC code. The vent is 2" and the stack is 3". They will run directly to the sewer at the lower level with no other fixtures entering the stack and a tub on the floor below will enter the horizontal
drain but it has it's own separate vent.
