Practical pressure testing water lines & stop valve
Rossn
Denver, CO
I am part-way through my re-plumb... got in the 1-1/4 main distribution branch, and cold to some fixtures (shower, tub, lav) connected.
The work completed thus far is 98% copper press (Viega fittings) and the rest PEX-A.
What practical level of testing are you usually comfortable with? Testing with air OK on this type of plumbing?
The inspector doesn't seem to care, knowing it is a remodel and I would see any leaks.
I've run an air test for 1 hr at 60 psi (same as our static pressure), and leaked down 3 psi. I went and closed all the stops and am re-running the test. I have about 9 ball valves for shutting off areas of the house, external hose bibs, etc. There is one Moen Flo, and one new stop valve.
My family has been without water for a few days, and so I need to turn it on this afternoon, but want to be 'comfortable enough'. I will have access to the plumbing for many months, so if any small leak is discovered, it is not a huge deal.
Side note - I don't have a lot of experience with compression fittings. I turned about 220 degrees through a turn, and it was quite tight.... I don't hear any air leaking. Any chance I need to tighten it more?
You could use a bubble solution to check for a leak. That is more sensitive than hearing.
Rossn
Denver, CO
fair enough. I just want to be comfortable it doesn't come flying off and flood the place. I'm not sure how uncommon it is to only have to tighten a compression fitting 2/3 of a turn.
You mean 2/3 turns beyond hand tight?
Rossn
Denver, CO
Yes
it definitely leaks down much faster (maybe 1 psi/min) when 80 psi. My daughter needs a bath - I don’t think it is a massive leak or I would hear the air rushing. I’m going to hook up the water and keep an eye out. As long as it is a slow leak, I have plenty of time to track it down. If it was an impressed fitting I think it would make a lot of noise.
