Possible to convert a green sand filter
chrisgjim
Have a green sand filter that is ten years old.Have not used it in the last few years because the medium tank would always get clogged. Want to put in a new system but was wondering if it would be cost effective to change the tank to a Manganese Dioxide system. It just seems a shame to toss out the tank.
ditttohead
Water systems designer, R&D
Ontario California
When you say medium tank, do you mean the media tank or the pot perm tank?
It can be easily converted, but when you say a magnesium dioxide tank, are you looking to convert it to a maganese dioxide ore mineral? Greensand is a manganese dioxide coated media.
Manganese dioxide ore (pyrolox, Filox etc.) is a very heavy media that requires considerable backwash rates to operate properly. What control valve, tank size, and water temperature do you have?
chrisgjim
Here is what I have. Water softener works fine but is ten years old. My iron filter tank is 10X54 It is ten years old and uses a brine tank for potassium permanganate. We had trouble with it plugging up or just going thru a ton of potassium. My water test came in at iron 2.0 mg/l hardness 180 mg/l ph 7.38 tested my flow rate and it was 12.75.
I had (probably a stupid idea) of just replacing the valve on the iron tank and changing the medium in the iron tank with something that would be better than what I have. Can it be done and is it cost effective. If you guys think I should just buy a new system do you have any recommendations.
ditttohead
Ontario California
It depends on the control valve you currently have. Can you post a picture? Medias have come a long way and there are many great and cost effective medias that replace greensand.
