Posi-Temp Shower faucet control directions changed after cartridge replacement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Shobuddy, Jun 17, 2020.
  1. Shobuddy
    Shobuddy New Member
    Nov 1, 2016
    Maryland
    I just replaced the cartridge on my Moen single handle shower. The controls used to be as follows:
    South - Off
    East - Cold
    North - Warm
    West - Hot
    After putting it back together, everything shifted 180 degrees so now it is:
    South - Warm
    East - Hot
    North - Off
    West - Cold
    Not sure what I did wrong putting it back together. Any input would be great.
  2. Terry
    Aug 17, 2004
    The cartridge can be reversed in case the hot and the cold were not plumbed correctly.
    Remove the clip, pull it out slightly and rotate the cartridge 180 degrees.
    [​IMG]
    Normally at the top of the cartridge, there will be on H on the left side, assuming there was hot plumbed to the left of the valve.
    [​IMG]
  4. Marlinman
    Marlinman In the Trades
    Dec 13, 2018
    Jacksonville Florida
  5. hj
    hj Master Plumber
    Whether they rotate the cartridge or rotate the stem depends on WHICH Moen stem it is.
  6. Shobuddy
    Shobuddy New Member
    Nov 1, 2016
    Maryland
    Thanks for the responses! Using the Moen 1222 cartridge and rotating the stem worked.
Similar Threads: Posi-Temp Shower
Plumbing Forum, Professional & DIY Advice Moen Posi-Temp shower cartridge stuck Nov 18, 2019
Plumbing Forum, Professional & DIY Advice Moen Posi-Temp, Tub/shower valve leak Feb 24, 2019
Plumbing Forum, Professional & DIY Advice Stuck Moen Posi-Temp shower cartridge components Jan 2, 2019
Plumbing Forum, Professional & DIY Advice Need advice on how to remove this Moen Posi-Temp shower stem Jul 9, 2015
Plumbing Forum, Professional & DIY Advice Brand new Moen Posi-Temp Tub & Shower Valve, Model 2300: Apr 4, 2010
