I have a LG portable AC unit (10,000 BTUs). I noticed it started cooling very poorly recently. Took it apart, used an IR thermometer, and found that the inputs to the evaporator coils got VERY cold (under 30 deg) and frosted over. But just a few inches past that, the coils were almost room temp. And the input to the condenser coil was almost room temp. So it appears that the coolant is being cooled well, but not flowing. Does this mean there is low coolant? Or a blockage impeding flow? I suspect low coolant since both inputs to the evaporator get very cold, and both evaporator coils warm up a few inches in. Thanks for any input!!
Signs Your Air Conditioner is Low on Refrigerant
Unexplained High Energy Bills
Often, the first thing that will alert you to a serious problem is an increase in your energy bill. Chances are good that you might not even notice that your air conditioner is working harder to keep you comfortable until your energy company makes it apparent.
Trouble Maintaining Comfort Level
If the air that is coming from your vents doesn’t seem as cold as it once did, if it seems like it’s taking ages for your home to cool off, or even if you can’t get the temperature down to a comfortable level, then low coolant may be the problem. The coils in your air conditioner won’t get as cold as they should when there isn’t enough coolant in them, and this means that the air passing over them can’t get as cold as it did before. As such, your air conditioner is working much harder, but without fixing the leak and recharging the coolant, it won’t be able to get the job done.
Ice on the Outdoor Part of the Unit
Finally, the last big giveaway that your air conditioner is low on coolant is the formation of ice on the outside component known as the compressor. Whenever there isn’t enough refrigerant in the system, the pressure drops in the evaporator coil. This allows the temperature to drop at the same time, causing the coil to drop below freezing and develop what could be a thick sheet of ice – even if it’s 100 degrees outside. The humid air hits the below-freezing coil and condenses there, and the beads of water forming as a result freeze rather quickly. This continues over and over again until the unit is iced over.
Regards!
