I'm looking at re-wireing the pump at my pool. Currently, all the electrical outlets by the pool (for pump and pool lights) are controlled by a timer in the garage. At night, to turn the lights on in the pool, I also have to turn on the pump by manually turning on the timer. I'd like to have a "always hot" outlet as well as a "timer" outlet out by the pool. I like the fact that the timer is in garage and don't want to install an outdoor timer.
I attached pictures as I'm not good at explaining exactly what I want to accomplish.
There is 12/2 NM coming into timer I want to then transition that to 12/3 going out to pool. Inside the timer box I'd connect the hot from 12/2 to the red of the 12/3 (that will be my always hot line for lights) and also connect a hot line to the timer's hot "input". Then the timers hot "out" line would go to the black of the 12/3. The 12/3 would go to a box outside the garage and transition into THHN/THWN through conduit to pool.
Can I do this? Or do I have to run two 12/2 lines out to outdoor box?
Like I said, I'm horrible and explaining things so see attached pics.
Figure 1: alternate way to wire it.
Figure 2: what I want to do.
Figure 3: electrical by pool.
Also any tips or comments also welcome
Thanks in advance.
Thanks in advance.
