interalian
I have a basic 15A circuit in the main service panel to the attached garage for lights and the code-minimum plugs. The original owner also had a 40A 240 line run to a range plug for some reason. I have no use for that and would like to convert the circuit to feed an 8 or 10 circuit pony panel and have some 15A 120 circuits and a 15A 240 circuit for an air compressor. Problem is, the last 15' of the existing run of cable is partially routed through a wall and I don't want to demolish a bunch of finished main floor drywall or exterior siding to extract it. I can cut it just before it disappears up from the basement and abandon that last 15', but the remaining cable will then be too short to reach from the main panel to my desired pony panel location.
So, is it acceptable to have a junction in a line like that? Or not. If not, I'll need to buy 100' of 8/3 - not cheap.
Also, if I do abandon that last 15' of cable, is there anything special I need to do with it? Mark it somehow?
Yes, I know I don't tie neutral to ground in the pony panel, and the work will be inspected as part of a current basement renovation. How high off the garage floor does the bottom of the ponly panel have to be?
