Pole Barn Supply Line Sizes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Reicherb, Oct 30, 2020.
  1. Reicherb
    Reicherb Member
    Nov 7, 2013
    Linden, MI
    I'm running water and gas to a pole barn 150' from my house. My house has 1" water (well) and 1" NG supply lines. I'm trying to determine what size lines and types to run to the barn.
    The barn will have a single half bath and a spigot to water our garden (200' from house)
    The barn will have a combi boiler that likely will take a 1/2 supply (haven't made a final decision)
    I'm inclined to run :
    3/4" Polyethylene Pipe directly buried for gas (the yellow stuff)
    3/4" water supply line
    is 3/4" enough for the water at that distance? Is 1" better? Is PEX ok to bury? is there something better?
    Thanks.
  2. Reicherb
    Reicherb Member
    Nov 7, 2013
    Linden, MI
  4. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    I don't think so. You want something rated for at least 150 psi. I am also wondering why they don't specify that it is SIDR (ASTM D2239) pipe that fits standard barbs, but it probably is. Why not specify?
    Actually I am not sure 100 is not enough. But if you were to put a check valve in series with your future water softener, feed this pipe with soft water, and the thermal expansion tank on the water heater fails, pressure could rise to 150. Unlikely, but he price premium is not much, and it is only a little harder to handle than 100 psi pipe.
    https://www.menards.com/main/plumbi...3210/p-1444431564085-c-8570.htm?tid=-1&ipos=8 does specify SIDR and is rated 160 psi.
  5. Reicherb
    Reicherb Member
    Nov 7, 2013
    Linden, MI
    Thank you very much.
    Do my line sizes make sense? 3/4" good enough for water at that distance?
Similar Threads: Pole Barn
Plumbing Forum, Professional & DIY Advice Pole barn bathroom Aug 20, 2019
Plumbing Forum, Professional & DIY Advice Wet Vent for toilet and sink in pole barn Jun 26, 2017
Plumbing Forum, Professional & DIY Advice Bathroom and Washer in Pole Barn May 26, 2014
Plumbing Forum, Professional & DIY Advice floor drain vent problem in pole barn Nov 2, 2011
Plumbing Forum, Professional & DIY Advice Hot Water in a dog barn Aug 20, 2021
