Plumbing through crawlspace questions
Giantsean
Hey all.. I'm in CT and plan to run some 3/4 pipe to feed a new hose bibb and eventually a sink in/near my garage.. Wanted to go big since I often run sprinklers and want as much volume as possible.
My house is old and has been added on to. Plan on running pipes in a crawlspace under a newer breezeway between house and garage. Crawlspace is mainly for storage (walk out basement) and houses central air ducts. A shutoff will be installed in case but the space rarely gets cold enough to fully freeze.
So I had two questions:
- I was planning to run 3/4" PEX as will be WAY easier routing for this application, but I know copper has slightly better flow/volume. Would copper be THAT much less restrictive for this short run (maybe 10 ft max) to make it worth doing for effectively a hose and a sink?
- For the bibb, I need to exit through the front of the crawlspace through the framing then a brick facade. I have the choice to run through the plywood sheathing OR go up a little further into a joist and through the rim joist. Does code allow either option? Going through the rim joist is more work dealing w/ insulation and it will come out a bit high off the ground. Not too worried about support through plywood as the brick will hold it steady and will sleeve the pipe.
Thanks for any advice!
No. Your spigot and garden hose will probably be more the limiting factor for flow.
Note you are required to support PEX at least every 32 horizontal inches.
Thanks. and yeah I over-clamp as it's my own house :D. Any difference in the exit point? (plywood vs rim) - def easier going through the sheathing... I don't THINK it's prohibited but worth asking if only to eliminate risk of having to make a 2nd hole through a brick wall someday.
