My question in a nutshell: should I change this plumbing, or just install the solid surface walls around the existing setup.
The details: I am in the process of preparing my tub walls to install some solid surface material in a kit. I have an odd problem though - The previous owner (a plumber actually, but he foreclosed so possibly not a good one!) did something strange with this tub alcove. See picture below.
As you can see, he originally put the shower mix valve/handle on the back wall of the tub, along with the spout. When I originally remodeled this tub 8 years ago, I moved the spout to the normal wall (right side, below the showerhead) but was leery of messing with the shower valve/handle plumbing.
Now however, I am finding that the solid surface kits have problems with a shower handle in this location. For example here is the kit I am thinking of getting:
http://www.swanstone.com/products/tubWalls/ss2960/index.php
This kit has 2 back panels and a 4 inch batten panel that join RIGHT where that shower handle sits in my bathtub alcove. I'm thinking this might be a problem. I COULD just cut out a hole barely big enough for the delta handle to pop through, but that might make it tougher to replace parts in future. If I make the hole as large as it previously was, it will take most of the material out of that batten strip, and possibly expose the seam in the surface to water seepage. That's my thought at least.
On the other hand, it seems like it might be a royal pain to replumb those lines over to the normal showerhead wall.
My experience with copper plumbing is fairly weak - I managed to do a bunch of plumbing correctly 8 years ago when I did the house remodel, but it took me several tries to get the solder to seal well each time. I'm sure I could do it, but not sure if I shouldn't just leave this non-leaking shower valve alone!
So, my question is: should I re-plumb this to "normal style" tub setup and make it easier to install the solid surface, or should I leave the working plumbing alone and work the solid surface around it. Any tips or ideas would be welcome as well, as I'm sure I'm not thinking of all the complications here.
As for the pro plumber option, there is no-one in this town (Bellingham) who isn't booked through September, or who wants to do a small job like this, so it's not really an option.
Here's a closeup of the shower valve assembly, if that helps:
