Plugged toilet or drain?
Discussion in 'Toilet Forum discussions' started by banjo bud, Jul 20, 2020.
  1. banjo bud
    banjo bud Member
    Sep 24, 2018
    South Carolina
    When my father in laws toilet Is flushed, it goes down ok but not as fast as it did a week ago. If you throw TP in it, then flush, the water rises in the bowl to almost overflow, then takes maybe 3 minutes to drain. Then, an hour later it goes back to flushing ok but not great
    again. I snaked down through the toilet and can get through the S turn but then the snake stops at about the bottom of the toilet where it would go into the floor. My thought is that something got dropped into the toilet like a pill bottle, or a pair of glasses etc. Then that object got stuck in the last turn of the trap. It’s not big enough to block the toilet from flushing liquid but TP gets hung up on the object. Then the TP dissolves and it goes back to working, but works just ok. So, I’ll take the toilet off it’s mount, turn it over, remove the object, put a new wax ring on and remount it. Is my logic good or bad? I should also ad that the toilet 5’ upstream From this one flushes fine and it’s on the same drain line.
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Your logic is good, except if it needed a plunger more than once/year/person before it degraded, consider a new toilet. You will go through most of the work to just pull the old toilet, so putting in a new one would not be much extra work. New ones usually flush better.
  4. banjo bud
    banjo bud Member
    Sep 24, 2018
    South Carolina
    The toilet is only 3 years old.
  5. jadnashua
    There could be a partial clog in the toilet, or, it could be further down the line. If the backup is variable, that implies it may be further down the line.
Similar Threads: Plugged toilet
Toilet Forum discussions Toilet plugged May 16, 2019
Toilet Forum discussions Badly Plugged Toilet Sep 9, 2017
Toilet Forum discussions Toilet Plugged Dec 15, 2015
Toilet Forum discussions Plugged Toilet Mar 13, 2011
Toilet Forum discussions How to use a closet auger on a plugged toilet Jan 21, 2008
