pls advise on hot&cold water inlet piping
Discussion in 'Water Heater Forum, Tanks' started by chrisoffice, Jun 30, 2020.
  1. chrisoffice
    chrisoffice New Member
    Jun 30, 2020
    GA
    [​IMG]
    I am going to replace this 10+ year old water heater, and am thinking about re-do all the pipework that goes into the water heater, as shown on the picture, those copper pipes are covered with greenish corrosion.
    The cold water goes from the water main to the water heater directly, the original installer made several turns on the copper pipe before it goes into the heater, to reduce the water pressure maybe?
    I am going to use the 18-inch flexible pipe to connect both the hot and cold water to the water heater. Now the question is, because I am getting rid of all those copper pipes shown on the picture, and maybe it is not a good idea to directly connect the new flexible pipes to the remaining outlets in the wall. How should I run the new copper pipes from the wall outlet before it connects to the flexible pipes?
  2. chrisoffice
    Jun 30, 2020
    GA
    BTW, the original installer did not install a thermal expansion tank, and it worked fine for the past 10+ years. It is a condo unit, I believe there is a check valve for the entire subdivision, but not for each individual condo unit. So probably the thermal expansion tank is not needed.
      File size:
      56.9 KB
      File size:
      56.9 KB
  4. fitter30
    fitter30 Active Member
    Feb 2, 2020
    Retired service tech
    Peace valley missouri
    All that green on the pipes probably flux that ran down the pipes when installed. Replace that gate valve with a full port ball valve. That cold piping was probably to close between the drop and pipe out of the heater for two 90s ( elbows) and installer didn't have the fittings to make that close offset.
    phog likes this.
Similar Threads: advise hot&cold
Water Heater Forum, Tanks Advise on Anode rod Dec 14, 2013
Water Heater Forum, Tanks Need advise on Electric Water heater - Rheem or Bradford White or other Mar 6, 2010
