Hi, I've been a long time lurker on these forums, and finally had a question that I could not find an answer for, so I decided to register.
Im in the process of building a brand new bathroom in my house (a single story bungalow), and wanted to run this "diagram" by the plumbers on this forum. This room will be brand new (formerly part of a bedroom), so there is no existing plumbing. I took the image off the internet, and modified it to reflect my situation. The only difference is that I will have a shower stall instead of the bathtub on this picture, but that doesn't matter for the purposes of this thread.
note: the shared "wet" part of the shower vent will be 2.5", not 2" like the picture says.
The 3 drains will merge into a single 3" pipe that will run horizontally approx. 20', before dropping down into the main drain line in the basement. The pipe will run perpendicular to the wall where all the plumbing is.
My main problem is that I will not be able to run a dedicated vent for the wall-hung toilet. Will the 2 shared vents for the sink/shower be sufficient?
I would prefer to keep the diameter of these 2 vent pipes going into the attic/roof to a minimum. The wall in question is not load bearing, but it is only 2"x4" framing and it will be fully tiled, with wall hung toilet and a heavy vanity hanging on it, so I don't want to compromise it any more than I have to by cutting huge holes in it for the vents. Will 1.5" diameter for each pipe be sufficient? Can I get by with less?
Above the sink will be a recessed cabinet, and above the toilet will be the in-wall tank, so I obviously cant run a vent pipe straight up at those locations.
Any other problems you guys see with this setup? Im located in Ontario, Canada but im not too concerned with the code (the house is not getting sold or inspected any time soon. I just want it to work and drain correctly. Any help or recommendations greatly appreciated!
