My wife and I had my bathroom redone. The wife chose a combo shower system from Sunrise
https://srsunriseus.com/products/10...1&_sid=28b6d7ef7&_ss=r&variant=39411990757541
The plumber and contractor installed and tested the shower. No problem. Then my contractor tiled the floor and walls and installed the new vanity. Then the banging noise started. Any cold or hot faucet opened and closed quickly in the house makes a banging noise exactly where the shower valve is installed. The noise reverberates powerfully throughout the pipe system.
The plumber has been back twice. What he’s done 1 – Drain the water from the system: this helped greatly, but when the new shower was activated again, the banging returned. 2 – Install water arrestors under the vanity: this did not work, noise still there. 3 – Ordered a new cartridge for the same shower model: the noise was the same. 4 – Dissemble the shower faucet hardware. The plumber inspected the cartridge and found that the metal cylinder in the cartridge regulating hot/cold water was making noises when he shook it. He is convinced this part is the culprit.
My plumber says that I can try living with the noise or the tiled wall needs to be opened. Now I would like to avoid both these options, so I am looking for the opinions from very creative and smart people to help me solve my problem by other means.
A few thoughts:
1 – Would it be possible to buy a compatible cartridge from another manufacturer? My cartridge looks very similar to this one https://www.amazon.com/Cartridge-Ceramic-Washbasin-Replacement-Accessories/dp/B075PGZ68L
2 – Could we try to put a tiny bit of duct seal (or something else) in both ends of the cartridge chamber to soften the blow/noise coming from the moving cylinder?
3 – Is it possible to remove/install a compatible shower valve without destroying the surrounding wall (a smaller valve)?
4 – Any other solutions worth investigating before I open up the tiled wall?
Thanks a million guys
A few thoughts:
