Can someone please help me resolve an issue I'm having with my Mancessa (by Mansfield) 4860 toilet?
When I flush the toilet water from the tank flushes the waste down the drain, the flapper closes, the tank refills with water up to the water line and the ballcock valve shuts off completely. My problem is that the bowl is only partially filling to perhaps 50% of the water that used to fill the bowl. To me it seemed that the flapper was closing too quickly so installed a new flapper and the result is still the same.
I contacted Mansfield Plumbing Products and they were not helpful as the Mancessa line of toilets are made in Columbia, South America and shipped directly to big box stores in the US so they apparently do not support these foreign made toilets.
When I look at the insides of the toilet it looks the same as most any other toilet I've seen with a typical ballcock fill valve on the left side with a small hose that is attached to an overflow tube and a standard size flapper attached to the handle with a chain. So far the only way to fill the bowl up to the original water level is to hold down the handle to keep the flapper up while the toilet flushes and then fills the bowl to an appropriate level. Can anyone explain what's going on and how to fix this problem? Thanks!
