Please Help! I think the renovation team has installed my shower lever wrong.
Amandalovessunlight
New York City
Hi,
Last year my bathroom was renovated and I was super pleased with the job...all is well yay, but the only complaint I had was that I was getting no hot water from the shower lever. They fixed that. Yay. Again.
Fast forward to today...a year later and I'm only noticing NOW that I'm only getting hot and lukewarm water...which isn't a big deal (I'm not a complainer! honestly!) BUT now I've noticed that it is a 180 degree lever and it only goes 90 degrees.
Also, the lever is from Delta. It is supposed to be set so the off position is at 3oclock and turns 180 degrees counterclockwise to gradually go from cold to hot. Mine is set for the off position to be at 9oclock and to get hot water it turns a little bit counterclockwise...(not tooooooo much otherwise it goes to lukewarm) to the 6oclock position and stops there. To turn it off I turn it clockwise back to the 9oclock position.
I'm trying to get the renovation team out here to fix the issue. How much will this be? Is it an easy fix? I hope so!
Here is a picture of what it should look like:
Mine looks like this. Its currently "off" and turns downwards and stops at the 6oclock position for lukewarm only. It never gets cold.
Thank you guys!
James Henry
Billings, Montana.
Take the handle off. If nothing falls out that looks like little pieces of broken plastic then the plastic parts that are for setting the temperature
and handle position probably just slipped into a different position or are worn out.
If that doesn't fix it then rebuild the shower valve.
Sylvan
Still learning
New York
I install Delta exclusively in NYC (pressure balance) and only once did I have to replace the cartridge .
When do install them I show the owner or building staff how to adjust the temperature for seasonal changes .
Delta does have time guarantee on parts
