FD_Man
Hi there. I recently had a Fleck 9100 SXT installed by a plumbing company. They were very proficient with the plumbing portion, but I didn’t get a warm fuzzy that they knew much about programming the softener. The plumber made a comment that these were the programming values that he always uses, which made me a little concerned. Maybe he knew more about it than he let on, and just didn't want to spend the time explaining it to me. Who knows. I just wanted to double check to make sure the settings looked reasonable.
Here is what I know about the softener:
Fleck 9100SXT twin tank
Used three 1 cu ft bags of resin to fill both tanks (1.5 cu ft per tank I’m assuming).
BLFC: 0.5 GPM
DLFC: -
Injector: 01
Looks like resin tanks are 10” in diameter
Water is from a well with a 1" or 1-1/4" line into the house. We currently have two adults and one toddler, with the expectation to add one or two more kids into the mix.
Here are the water test results from KAR Labs (I have four pages, but to save typing only pulled out line items that I thought were pertinent, let me know if you need something else).
Iron: None Found (<.01 mg/L)
PH: 7.6
Hardness: 25.9 gpg
Turbidity: None Found (<1 NTU)
Total Dissolved Solids (Estimated): 550 mg/L
Manganese, total: .007 mg/L
Sulfur, total, by ICP: 20.0 mg/L
Here are the programmed values:
DF: GAL
VT: dF1b
CT: FI
NT: ---2
TS: U2
C: 30
H: 26
RS: SF
SF: 5
DO: 7
RT: 2:00
BW: 10
BD: 60
RR: 10
BF: 6
FM: t0.7
Please take a look and let me know what you think.
BLFC: 0.5 GPM
DLFC: -
Injector: 01
PH: 7.6
Hardness: 25.9 gpg
DF: GAL
VT: dF1b
CT: FI
NT: ---2
TS: U2
C: 30
H: 26
RS: SF
SF: 5
DO: 7
RT: 2:00
BW: 10
BD: 60
RR: 10
BF: 6
FM: t0.7
