If while pumping 10+ GPM the water level only pulled down to 72', then you have more than 10 GPM recovery from 72'. It doesn't matter the recovery rate to get water back to full static level. What matters is how much water you can pump without drawing the well down and running the pump dry. If the water level did not get any deeper than 72' while pumping 10+ GPM, then your pumping level is 72' and the well can produce 10+ GPM.
