DStyduhar
Ok, it's becoming clearer. Maybe
For my situation, maybe I should think about TDH in terms of two legs. Leg A is between well and house and then leg B will be between house and garage. I can calculate leg A head based on HOUSE GPM needs and then I can figure what gpm/psi I will have available to the garage due to additional pipe loss. If not enough to satisfy garage needs, then step up to next pump hp.....like 3/4 to 1hp assuming wiring can handle it. Or maybe increase pump gpm....7 to 10 for instance. Does this make any sense? Is there a big downside to oversizing the pump slightly?
Regarding TDH calculation (Total Dynamic Head (TDH) = Pumping lift + elevation change + operating pressure + friction loss), I'm hung up exactly on what they mean by Pumping Lift? If the pump is 100 feet down, do you just put 100? Or is this the pumping level? If pumping level, I only have that value for the max gpm of the well.
thanks,
Drew
thanks,
Drew
