Plastic connector for sink sprayer won't come off
John Ramirez
Illinois
Hi all,
I just moved into a new apartment and i am trying to install a reverse osmosis system. I don't want to drill a new hole in cast iron/enamel sink, so I want to remove the sink sprayer to install the water faucet for the RO system. I have heard you have to push the tabs on the plastic part in and up, and then pull the hose. Is this correct? It is really hard to get in there, and I haven't been able to remove it.
Also do I have to cap something after the hose is removed?
Thanks in advance
John Ramirez
Illinois
here is a pic
That has a push-in, and then pull while it's pushed.
You will need to do something with it. It may be easier to just replace the faucet.
John Ramirez
Illinois
So let's say i remove the hose. Once the hose is removed i install the new water spicket in the hole. Will i need to cap the line for the sprayer?
How about plugging in the sprayer under the sink? Hokey but hidden.
Smooky
North Carolina
This is some info from the Delta Q&A from the link I provided above:
To remove the RP54807 spray hose you will need to press in on the textured portion on the tabs on 2 sides of the white block connector. Once you have applied pressure, push up slightly and then pull the hose down off the fittting.
Once you remove the hose and remove it from the extra sink hole you could reconnect it to the undersink block connector as Reach4 said above.
Another option from the delta link above:
You can use the RP60295 to cap off the sprayer hose connection.
You can order parts by calling our customer service line at 800-345-3358 or find dealers locally or online by clicking the link below.
http://www.deltafaucet.com/where-to-buy/index.html
Read more: http://www.deltafaucet.com/repairparts/details/rp54807.html#ixzz4DoVOFVYC
John Ramirez
Illinois
How about hiding the hose away? I like the idea. Less work to take apart and put back together. Do you know how to remove the end pieces?
Smooky
North Carolina
John, you need to climb up under the sink and take it loose under there. Take everything out from under the sink so you can access the connector. I use a foam kneeling pad to lay on when I have to do that sort of thing. Reach up and feel the white plastic block connector. On two sides it is smooth and on the other two sides it is textured. Pinch the textured sides in, push up while still pinching the sides in and then pull down ,keep the sides pinched in, pull down on the hose and it should come apart. Then remove it from the hole in the sink. Then plug it back together and just leave the little hose and sprayer under the sink.
John Ramirez
Illinois
Thanks for your help Smooky and Terry. I used the following video to remove the plastic pieces at the end of the hose instead of disconnecting underneath the sink, and put it back together under the sink. The RO system is working! Thanks for help again. For those having this issue, please use the following video to uninstall the sink sprayer without going underneath.
John Ramirez
Illinois
When I move out, I will have to put the water system back in place as it was. I had to drill a hole in the wastewater pipe for the reverse osmosis system. Is there an easy way to fix this when I move out. Or do I have to buy and install a new pipe?
Thanks again guys
