Ian Davlin
I'm replacing the pitless adapter on my well. I was told to tighten the lock nut until the brass part of the adapter inside the casing is flush up against the casing (metal on metal). I've tightened the nut as much as I can and I can't get it to make metal on metal contact. Is it normal to see the inside rubber washer in between instead of seeing the adapter touching the casing?
