I am installing a submersible pump in one of my dug wells in order to supply my greenhouse. I have dealt with pitless adapters on some of my drilled wells but never on a dug well.
I want to make sure that after I drill the hole into the concrete well casing I am able to seal it off so nothing gets into the well. I can see on 2 of my dug wells where the previous property owners chiseled away the concrete to make connections, but I didn't know if there was a better way. I thought maybe I would just drill the hole, run the pipe through with an elbow and then seal up around where the pipe goes through the side of the well. I am using poly pipe.
What is the best solution for this? Thanks a lot
