RetiredInGueydan
Active Member
I agree with your logic that an open drain valve is needed while priming jet pumps.Zero.
I am saying that if priming into a galvanized tank is easier than into a pre-charged pressure tank, then starting into an open drain valve would also make things easier. I am afraid I am trying to apply logic. Do you disagree with my logic?
I did not say that priming into a galvanized tank is easier. That was the pump company.
In part that you did not quote, I had discussed a non-priming thing -- the water level of the water drops to the level of the sand point screen while the pump is sucking. I would indeed expect the pump to be pumping a mix of air and water at that point. What would you expect? Jet pumps produce a vacuum. That sucks only water if there is only water at the screen. If the water level dropped, I expect to not suck only water.
I have not commented on galvanized tanks in this thread.
Apparently I missed your discussion on non-priming which was a brief version of what you describe here. With the next door neighbor having a spring fed system, I highly doubt that Chucky's sand point well has supply issues. I would suspect a leak between the check valve and the static water level is the source of any air in the system.
