DJR
Installed new tub and attached the drain pipes. Both the drain pipe coming off the tub and the drain pipe coming out from the flooring are the same size and are offset by a few inches. I purchased a brass drain kit because most of the pipes will be located in a crawl space and we get very cold weather. I was thinking PVC pipe would crack under extreme temperatures.
a couple of questions.
1. Can I use a rubber elbow to attach the tub drain pipe to the floor drain pipe ?
2. Is there a certain size pipe that will fit inside a tub standard drain pipe? I have yet to find one.
I know what would work ( see picture below) but I can't just buy the T attachment. I would have to buy the whole assembly and it would take weeks to get it delivered.
